Beats Studio Pro Earpad Replacement
Views: 3K
View statistics:
Past 24 Hours:
25
Past 7 Days:
126
Past 30 Days:
496
All Time:
3,042
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
With time, the earpads on your headphones can become worn out, causing discomfort and a decline in sound quality. You may easily and affordably replace your old earpads with news ones rather than buying new headphones.
This step-by-step guide will show you how to remove the old earpads and put in new ones. It only takes a few minutes, and no particular skills are needed. To restore comfort and extend the life of your Beats Studio Pro headphones, follow these steps!
    1. Beats Studio Pro Earpad Replacement, Earpad: step 1, image 1 of 2 Beats Studio Pro Earpad Replacement, Earpad: step 1, image 2 of 2
      • Grip the edge of the left or right earpad firmly.
      • Insert an opening pick under the earpad and work your way around the edge to pry it off.
      • Repeat for the second earpad.
      • If the earpads are old and sticky, they may come off in pieces. Take your time to remove them cleanly.
      Ask FixBot
    2. Beats Studio Pro Earpad Replacement: step 2, image 1 of 1
      • Slowly and carefully remove the old earpad.
      • Apply consistent, even pressure until the earpad starts to come out because the adhesive will resist at first.
      Ask FixBot
    3. Beats Studio Pro Earpad Replacement: step 3, image 1 of 3 Beats Studio Pro Earpad Replacement: step 3, image 2 of 3 Beats Studio Pro Earpad Replacement: step 3, image 3 of 3
      • Check for leftover adhesive on the speaker housing. Any residue left behind can make it difficult for the new earpads to attach properly.
      • Gently peel off excess adhesive or use adhesive remover to ensure cleanliness.
      Ask FixBot
    4. Beats Studio Pro Earpad Replacement: step 4, image 1 of 3 Beats Studio Pro Earpad Replacement: step 4, image 2 of 3 Beats Studio Pro Earpad Replacement: step 4, image 3 of 3
      • Use an alcohol or cleaning wipe to remove the residue left from the adhesive that you peeled off.
      • Make sure the surface is clean and dry before proceeding.
      • A firm attachment for the new earpads is ensured by a cleaned surface.
      Ask FixBot
    5. Beats Studio Pro Earpad Replacement: step 5, image 1 of 3 Beats Studio Pro Earpad Replacement: step 5, image 2 of 3 Beats Studio Pro Earpad Replacement: step 5, image 3 of 3
      • Check if the new earpads have pre-applied adhesive.
      • If they do, peel off the protective backing to expose the sticky side.
      • If not, apply double-sided adhesive tape to the back of the earpads.
      • Identify the left and right earpads and align the new earpad with the ear cup.
      • Press firmly onto the headphone, and hold for 30 seconds. This allows the adhesive to bond properly.
      • Repeat for the second earpad and ensure both sides are attached correctly.
      Ask FixBot
    6. Beats Studio Pro Earpad Replacement: step 6, image 1 of 1
      • Check that both earpads are securely attached. Run your fingers around the edges to ensure no part is peeling off.
      • Make sure to test the fit by wearing the headphones, they should feel more comfortable.
      • If any part feels loose, slightly add more pressure so that it ensures security.
      Ask FixBot
Congratulations! You've successfully replaced the earpads on your Beats Studio Pro headphones. This repair restores comfort and extends the life of your headphones, all without the need for expensive replacements. Enjoy your refreshed headphones!
Aeryon Reed
141 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 25
Past 7 Days: 126
Past 30 Days: 496
All Time: 3,042
