Beachwaver S-Series Clamp Spring Repair
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
190
All Time:
2,643
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to repair or replace the clamp spring of your Beachwaver S-Series Dual Voltage Rotating Curling Iron.
The clamp spring is a critical part that holds your hair in place against the rod—also called the heating barrel—of your curling iron. If your clamp is loose and no longer holds your hair against the rod, your clamp spring may be misaligned or broken.
The Beachwaver S-Series is available in three sizes. The S.75 has a 0.75" rod. The S1 has a 1" rod. The S1.25 has a 1.25" rod. The size of your curling iron will determine the size of the clamp spring you require.
Sometimes, a clamp spring may simply be misaligned. Before ordering a replacement clamp spring, follow the steps in this guide to determine if you can repair your device with the original part.
Before starting this repair, ensure the curling iron is turned off and unplugged. If you’ve recently used the curling iron, allow it to cool completely to avoid the risk of burns.
Parts
Tools
      • Ensure the curling iron is turned off and unplugged.
      • Ensure the curling iron is completely cool before attempting this repair to avoid the risk of burns.
      Ask FixBot
    1. Beachwaver S-Series Clamp Spring Repair: step 2, image 1 of 3 Beachwaver S-Series Clamp Spring Repair: step 2, image 2 of 3 Beachwaver S-Series Clamp Spring Repair: step 2, image 3 of 3
      • Insert the tip of your size 000 Phillips screwdriver into the pin hole at the base of the clamp.
      • Apply pressure to the top of your screwdriver to push the pin that secures the clamp to the rod out of your curling iron.
      • Store the clamp some place you will not lose it.
      Ask FixBot
    2. Beachwaver S-Series Clamp Spring Repair: step 3, image 1 of 3 Beachwaver S-Series Clamp Spring Repair: step 3, image 2 of 3 Beachwaver S-Series Clamp Spring Repair: step 3, image 3 of 3
      • Lift the clamp off of the rod.
      Ask FixBot
    3. Beachwaver S-Series Clamp Spring Repair: step 4, image 1 of 2 Beachwaver S-Series Clamp Spring Repair: step 4, image 2 of 2
      • Pull the spring from the base of the rod, where the clamp previously rested.
      • Install your replacement spring into the previous spring's location.
      • If your original spring is intact, it may have become misaligned. If so, reinsert the spring into the location shown in the images.
      Ask FixBot
Attached Documents
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 190
All Time: 2,643
