Bazic 3003 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
69
All Time:
679
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
After using your calculator for an extended period, the battery will eventually drain and you will need to replace it.
If you need to replace the battery in your Bazic 3003 calculator, follow this guide and you'll be back to solving math equations in no time! There aren't any special skills required to complete this guide Just be sure to turn off your calculator before you begin the repair.
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    Optional
    1. Bazic 3003 Battery Replacement, Bazic Calculator: step 1, image 1 of 1
      • Press the "OFF" button on your Bazic 3003 calculator.
      • Make sure it is powered off before you begin the repair.
      Ask FixBot
    2. Bazic 3003 Battery Replacement: step 2, image 1 of 1
      • Turn your calculator over so the back is facing up.
      Ask FixBot
    3. Bazic 3003 Battery Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the 1.0 mm screw from the battery compartment.
      Ask FixBot
    4. Bazic 3003 Battery Replacement: step 4, image 1 of 1
      • Only one button battery is needed for the calculator to function but you can add one or two.
      • Use your fingers or a plastic spudger to remove the battery from the calculator.
      • Insert the new button battery into the slot and push it into place.
      Ask FixBot
    5. Bazic 3003 Battery Replacement: step 5, image 1 of 1
      • Replace the battery door.
      • Use a Phillips #0 screwdriver to replace the screw and secure the battery door.
      Ask FixBot
    6. Bazic 3003 Battery Replacement: step 6, image 1 of 1
      • Push the "On" button on your calculator and check if the buttons work and function properly.
      Ask FixBot
Bryan Reyes
136 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 69
All Time: 679
