This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Battery change LeapFrog reader
    1. Battery change LeapFrog reader, Disassembling the pen to access the battery: step 1, image 1 of 3 Battery change LeapFrog reader, Disassembling the pen to access the battery: step 1, image 2 of 3 Battery change LeapFrog reader, Disassembling the pen to access the battery: step 1, image 3 of 3
      • Unscrew the two long screws located on either side of the mini-USB port, under the blue rubber cap.
      • Spread the two white parts at the top of the pen (headphone socket side) as shown in photo 2, then lift the front panel to release the tabs from the bottom section.
      • CAUTION: do not pull the two white parts apart: two thin wires (red and black) connect the motherboard on the back section to the speaker on the front section! See the following photos before spreading the two parts!
      Ask FixBot
    2. Battery change LeapFrog reader, Motherboard Disassembly 1/2: step 2, image 1 of 3 Battery change LeapFrog reader, Motherboard Disassembly 1/2: step 2, image 2 of 3 Battery change LeapFrog reader, Motherboard Disassembly 1/2: step 2, image 3 of 3
      • During all the following steps, do not separate the front part and the motherboard so as not to tear the two speaker wires.
      • Remove the two top screws and the one located at the bottom to release the motherboard.
      • To remove the motherboard, you must remove the green part at the bottom of the pen: remove the two visible screws, then proceed to the next step.
      Ask FixBot
    3. Battery change LeapFrog reader, Motherboard Disassembly 2/2: step 3, image 1 of 3 Battery change LeapFrog reader, Motherboard Disassembly 2/2: step 3, image 2 of 3 Battery change LeapFrog reader, Motherboard Disassembly 2/2: step 3, image 3 of 3
      • Pull downward with a quick, firm motion to disengage the snap fits. You can use a spudger to help, but ABOVE ALL, never do this if the plastic is below 22 °C: it risks breaking instead of deforming!
      • Remove the small white plastic part, paying attention to the orientation of the piece and the detection plate on the top side.
      • Once the green part is removed, you can lift the lower part of the motherboard out of its notch.
      Ask FixBot
    4. Battery change LeapFrog reader, Accessing the battery: step 4, image 1 of 3 Battery change LeapFrog reader, Accessing the battery: step 4, image 2 of 3 Battery change LeapFrog reader, Accessing the battery: step 4, image 3 of 3
      • Unplug the connector indicated by the bubble.
      • Move the motherboard aside to reveal the protective casing of the Li-Po (lithium-polymer) battery.
      • Remove the battery, which is neither fixed nor glued in place.
      Ask FixBot
    5. Battery change LeapFrog reader, Opening the battery casing: step 5, image 1 of 2 Battery change LeapFrog reader, Opening the battery casing: step 5, image 2 of 2
      • Peel back the metal plates to access the battery itself and remove it from the black casing.
      • The battery has the standardized part number 781469: 3.7 V, 2.8 Wh, or 750 mAh. It measures approximately 73 × 14 × 8 mm. It has three wires (+/− and control).
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Corbanizer is helping us fix the world! Want to contribute?
Start translating ›
Madcat
1,340 Reputation
9 Guides authored
4 Guide Comments
Les câbles pour le micro se sont malheureusement décrochés. Y a-t-il un moyen de les remettre?
Antoine Six - Reply Share
Oui, il faut juste les ressouder, le rouge en haut. Sur l’une des photos on voit là où se branche le fil noir.
Madcat - Reply Share
Bonjour
Ou trouve t on ce genre de batterie ?
Jenny Larue - Reply Share
Bonjour, sur Aliexpress, mais c'est difficile, ce n'est pas une taille très standard.
Past 24 Hours: 9
Past 7 Days: 25
Past 30 Days: 69
All Time: 665
