Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015
  1. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015, Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 1, image 1 of 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015, Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 1, image 2 of 2
    • Remove the following pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 2, image 1 of 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 3, image 1 of 1
    • Peel back the warning label covering the battery connector.
  4. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 4, image 1 of 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 4, image 2 of 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 4, image 3 of 3
    • No metal tools!
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 5, image 1 of 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 5, image 2 of 2
    • Remove the following T5 Torx (verify?) battery screws.
  6. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 6, image 1 of 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 6, image 2 of 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 6, image 3 of 3
    • There is risk to damage the battery! (Do not use ANY metal tools - puncturing the battery can cause fire and possibly leak battery gel!)
    • Please note: carefully cut the duct tape layer under the battery with thin wire string. Pull back and forth slowly. Do not pry up with any metal tools.
  7. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 7, image 1 of 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 7, image 2 of 2
    • Be sure you did not damage the loopback of the track-pad!
    • Please lift up the plaque under the battery with metal spudger.
  8. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 8, image 1 of 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 8, image 2 of 2
    • Remove battery
  9. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 9, image 1 of 2 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 9, image 2 of 2
    • Using the flat end of a spudger, pry the trackpad connector.
  10. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 10, image 1 of 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 10, image 2 of 3 Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 10, image 3 of 3
    • Unscrew the light-colored screws
    • Remove trackpad.
  11. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 11, image 1 of 1
    • Adjustment of trackpad touching level
  12. Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015: step 12, image 1 of 1
    • Good luck!
Aleksandr ApplePartsPRO
1,727 Reputation
1 Guide authored
AppleParts.PRO Member of AppleParts.PRO
Business
1 Member
4 Guides authored
Past 24 Hours: 5
Past 7 Days: 48
Past 30 Days: 239
All Time: 82,911
