Black and Decker SS12C Battery Replacement
  1. Black and Decker SS12C Battery Replacement, Battery: step 1, image 1 of 3 Black and Decker SS12C Battery Replacement, Battery: step 1, image 2 of 3 Black and Decker SS12C Battery Replacement, Battery: step 1, image 3 of 3
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: step 2, image 1 of 1
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: step 3, image 1 of 3 Black and Decker SS12C Battery Replacement: step 3, image 2 of 3 Black and Decker SS12C Battery Replacement: step 3, image 3 of 3
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: step 4, image 1 of 2 Black and Decker SS12C Battery Replacement: step 4, image 2 of 2
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: step 5, image 1 of 3 Black and Decker SS12C Battery Replacement: step 5, image 2 of 3 Black and Decker SS12C Battery Replacement: step 5, image 3 of 3
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
2 other people completed this guide.
1 Guide Comment
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 38
All Time: 1,128
