Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Prereq to removing the battery assembly or the individual battery cells.
Tools
Pull the left edge of the front bezel away from the device to release the plastic clip.
Use the cutout in the battery connector to pull it toward the right edge of the device and disconnect it.
Lift and rotate the battery connector to move it out of the way of the battery assembly.
Use a Phillips driver to remove the three 23 mm‑long screws securing the battery assembly.
Pull the battery assembly out of the housing until it stops at its first plastic tab.
