Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
With the exposed sides of the battery cells facing down, slide the battery cable under the lip of the ear cup so it sits on top of the charging port.
Place both battery cells into their recesses.
Use a Torx Plus 3IP screwdriver to install the three screws securing the battery cells:
Two 4.0 mm‑long screws
One 7.0 mm‑long screw
Use a spudger or your fingers to press down and connect the battery press connector.
Slide the battery connector cover's two tabs into their slots and lay the cover in place.
