Canon PowerShot A630 Battery Door Replacement
  1. Canon PowerShot A630 Battery Door Replacement, Front Panel: step 1, image 1 of 2 Canon PowerShot A630 Battery Door Replacement, Front Panel: step 1, image 2 of 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Battery Door Replacement: step 2, image 1 of 2 Canon PowerShot A630 Battery Door Replacement: step 2, image 2 of 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Battery Door Replacement: step 3, image 1 of 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Battery Door Replacement: step 4, image 1 of 2 Canon PowerShot A630 Battery Door Replacement: step 4, image 2 of 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Battery Door Replacement: step 5, image 1 of 2 Canon PowerShot A630 Battery Door Replacement: step 5, image 2 of 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Battery Door Replacement: step 6, image 1 of 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Battery Door Replacement: step 7, image 1 of 2 Canon PowerShot A630 Battery Door Replacement: step 7, image 2 of 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Battery Door Replacement, Back Panel: step 8, image 1 of 2 Canon PowerShot A630 Battery Door Replacement, Back Panel: step 8, image 2 of 2
    • Use the spudger to gently pull back the retaining clip and pull the ribbon out.
    • The top panel should now be completely detached from the camera.
    • Applying too much force to the spudger may damage the retaining clip.
  9. Canon PowerShot A630 Battery Door Replacement: step 9, image 1 of 2 Canon PowerShot A630 Battery Door Replacement: step 9, image 2 of 2
    • Remove .2 mm screw using a #00 Philips screwdriver.
    • Gently pry off back panel to remove it.
  10. Canon PowerShot A630 Battery Door Replacement, Battery Door: step 10, image 1 of 1
    • Remover .2 mm screw using a #00 Philips screwdriver.
  11. Canon PowerShot A630 Battery Door Replacement: step 11, image 1 of 2 Canon PowerShot A630 Battery Door Replacement: step 11, image 2 of 2
    • Using tweezers, gently pull remove the small rod in the battery door hinge.
  12. Canon PowerShot A630 Battery Door Replacement: step 12, image 1 of 2 Canon PowerShot A630 Battery Door Replacement: step 12, image 2 of 2
    • Gently pull up on the battery door to remove it.
2 other people completed this guide.
Alicia Burns
574 Reputation
5 Guides authored
Clemson, Team 2-5, Benson Fall 2014 Member of Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 40
All Time: 1,322
