Battery Disconnection
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Battery Disconnection, Before you begin: step 1, image 1 of 3 Battery Disconnection, Before you begin: step 1, image 2 of 3 Battery Disconnection, Before you begin: step 1, image 3 of 3
    • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
    • Optionally, to drain the battery faster, navigate to More → Settings → Energy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
    • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
    • Unplug all cables and fully shut down your eReader.
    • Your screen should be black and say Powered off.
  2. Battery Disconnection, Insert an opening pick: step 2, image 1 of 3 Battery Disconnection, Insert an opening pick: step 2, image 2 of 3 Battery Disconnection, Insert an opening pick: step 2, image 3 of 3
    • Flip your eReader over so the screen is facing down.
    • Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
    • Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
    • You may have to test a few spots along the corner until the pick slides between one of the clips.
  3. Battery Disconnection, Release the right clips: step 3, image 1 of 3 Battery Disconnection, Release the right clips: step 3, image 2 of 3 Battery Disconnection, Release the right clips: step 3, image 3 of 3
    • Slide the pick toward the bottom right corner to release the clips along the right edge.
  4. Battery Disconnection: step 4, image 1 of 2 Battery Disconnection: step 4, image 2 of 2
    • Angle the pick flat under the back cover and rotate it around the bottom right corner to release its clips.
    • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
  5. Battery Disconnection, Release the bottom clips: step 5, image 1 of 3 Battery Disconnection, Release the bottom clips: step 5, image 2 of 3 Battery Disconnection, Release the bottom clips: step 5, image 3 of 3
    • Slide the pick toward the bottom left corner to release the clips along the bottom edge.
  6. Battery Disconnection, Remove the back cover: step 6, image 1 of 3 Battery Disconnection, Remove the back cover: step 6, image 2 of 3 Battery Disconnection, Remove the back cover: step 6, image 3 of 3
    • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
    • Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
    • Remove the back cover.
    • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
  7. Battery Disconnection, Coating information: step 7, image 1 of 3 Battery Disconnection, Coating information: step 7, image 2 of 3 Battery Disconnection, Coating information: step 7, image 3 of 3
    • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
    • While this won't hurt your device, removing the coating compromises the device to potential water damage.
    • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
    • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
  8. Battery Disconnection, Disconnect the battery: step 8, image 1 of 2 Battery Disconnection, Disconnect the battery: step 8, image 2 of 2
    • Use a spudger to pry up and disconnect the battery press connector.
    • Don't pry against the motherboard, as you risk breaking small, surface-mounted components.
    • Your E-ink screen will continue to say Powered off even after disconnection—this is normal!
Alex Diaz-Kokaisl
216,554 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,906 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 137
