Portable Power Station Battery Disconnection
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Portable Power Station Battery Disconnection, Shut down your power station: step 1, image 1 of 3 Portable Power Station Battery Disconnection, Shut down your power station: step 1, image 2 of 3 Portable Power Station Battery Disconnection, Shut down your power station: step 1, image 3 of 3
    • Let your Portable Power Station's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Hold down the blue action button for five seconds to shut down your power station.
    • Collapse the kickstand.
  2. Portable Power Station Battery Disconnection, Remove the rear cover screws: step 2, image 1 of 2 Portable Power Station Battery Disconnection, Remove the rear cover screws: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a T10 Torx screwdriver to remove the two 8 mm‑long screws securing the rear cover.
  3. Portable Power Station Battery Disconnection, Remove the rear cover: step 3, image 1 of 3 Portable Power Station Battery Disconnection, Remove the rear cover: step 3, image 2 of 3 Portable Power Station Battery Disconnection, Remove the rear cover: step 3, image 3 of 3
    • Grab the rear cover and pull the bottom edge towards you.
    • Remove the rear cover.
    • Don't try to remove the enclosure while the battery is still connected, or you'll damage the battery connector.
    • During reassembly, hook in the top edge of the rear cover first, then press the bottom edge into place.
  4. Portable Power Station Battery Disconnection, Pry up the battery connector: step 4, image 1 of 2 Portable Power Station Battery Disconnection, Pry up the battery connector: step 4, image 2 of 2
    • To avoid an electrical shock, don't use metal tools to disconnect the battery.
    • Insert the flat end of a spudger into one of the slots on either side of the battery connector. They're shaped just for this!
    • Use the spudger to begin prying up the connector.
    • If it's your first time disconnecting the battery, this may take some force.
  5. Portable Power Station Battery Disconnection: step 5, image 1 of 3 Portable Power Station Battery Disconnection: step 5, image 2 of 3 Portable Power Station Battery Disconnection: step 5, image 3 of 3
    • Repeat the process and pry up on alternating sides of the battery connector to "walk" it off of the two plugs, enough that you can easily grip it with your fingers.
    • You may have to reposition your spudger to fully release the battery connector. Be careful not to damage the board if you pry against it.
  6. Portable Power Station Battery Disconnection, Disconnect the battery: step 6, image 1 of 2 Portable Power Station Battery Disconnection, Disconnect the battery: step 6, image 2 of 2
    • Don't try to force the connector off or you might hurt yourself on the metal edges of the enclosure. If the connector doesn't come off easily, continue prying up with your spudger until the connector is loose enough to easily disconnect.
    • Grasp the battery connector by its edges and pull straight up to disconnect it.
  7. Portable Power Station Battery Disconnection, Reassembly information: step 7, image 1 of 3 Portable Power Station Battery Disconnection, Reassembly information: step 7, image 2 of 3 Portable Power Station Battery Disconnection, Reassembly information: step 7, image 3 of 3
    • During reassembly, follow these steps to reconnect the battery:
    • Tuck the wires behind the connector, so the side of the connector with positive (+) and negative (-) markings is facing outward.
    • Make sure the wires aren't pinched by the enclosure.
    • Align the connector over its two metal plugs so the negative (-) side is on the left of the USB‑C port and the positive (+) side is on the right.
    • Slide the connector onto its plugs and push down firmly until it's fully seated.
Finish Line
Nick Schultz
39,248 Reputation
226 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,977 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 72
