Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Spudger4.9
Introduction
Go to step 1 ↓This is a prerequisite-only guide! This guide is part of another procedure and isn't meant to be used alone.
Use a Phillips screwdriver to remove the 10 screws securing the lower case:
Six 12Â mm screws
Four 4.5Â mm screws
Insert an opening pick between the lower case and the chassis on the front right edge.
Slide the pick along the front edge to release the clips securing the lower case.
Continue sliding the opening pick along the left and right edges to release the remaining clips.
Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
