Up to 20% off select tools
Battery Disconnect
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
35
All Time:
220
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Battery Disconnect
Tools
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and isn't meant to be used alone.
    1. Battery Disconnect, Unfasten the lower case: step 1, image 1 of 2 Battery Disconnect, Unfasten the lower case: step 1, image 2 of 2
      • Remove the 11 Phillips screws securing the lower case:
      • Seven 11.6 mm screws
      • Two 14.6 mm screws
      • Two 6.1 mm screws
      Ask FixBot
    2. Battery Disconnect, Insert an opening pick: step 2, image 1 of 2 Battery Disconnect, Insert an opening pick: step 2, image 2 of 2
      • Insert an opening pick between the lower case and the chassis on the front right edge.
      Ask FixBot
    3. Battery Disconnect, Release the right edge clips: step 3, image 1 of 2 Battery Disconnect, Release the right edge clips: step 3, image 2 of 2
      • Slide the pick along the right edge to release the clips securing the lower case.
      Ask FixBot
    4. Battery Disconnect, Release the remaining clips: step 4, image 1 of 3 Battery Disconnect, Release the remaining clips: step 4, image 2 of 3 Battery Disconnect, Release the remaining clips: step 4, image 3 of 3
      • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
      Ask FixBot
    5. Battery Disconnect: step 5, image 1 of 3 Battery Disconnect: step 5, image 2 of 3 Battery Disconnect: step 5, image 3 of 3
      • Lift the lower case from the chassis and remove it.
      • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
      Ask FixBot
    1. Battery Disconnect, Reposition the plastic: step 6, image 1 of 2 Battery Disconnect, Reposition the plastic: step 6, image 2 of 2
      • Use your fingers to move the plastic that covers the battery connector out of the way.
      • If the plastic is not staying out of the way use a piece of tape to secure it.
      Ask FixBot
    2. Battery Disconnect, Disconnect the battery: step 7, image 1 of 3 Battery Disconnect, Disconnect the battery: step 7, image 2 of 3 Battery Disconnect, Disconnect the battery: step 7, image 3 of 3
      • Use the flat end of a spudger to push each side of the battery connector until it comes out of the socket.
      Ask FixBot
Spencer Day
210,586 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 35
All Time: 220
