Battery Connector
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Battery Connector, Battery Connector: step 1, image 1 of 1
    • Remove the two Phillips screws securing the battery connector bracket:
    • One 2.9 mm screw
    • One 2.2 mm screw
  2. Battery Connector: step 2, image 1 of 2 Battery Connector: step 2, image 2 of 2
    • Remove the battery connector bracket from the iPhone.
  3. Battery Connector: step 3, image 1 of 3 Battery Connector: step 3, image 2 of 3 Battery Connector: step 3, image 3 of 3
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  4. Battery Connector: step 4, image 1 of 2 Battery Connector: step 4, image 2 of 2
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
Evan Noronha
223,653 Reputation
168 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,953
