Up to 20% off select tools
Base Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
15
All Time:
220
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Better Introduction
Improve this guide by completing or revising its introduction.
Base Replacement
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
Prerequisite Only
    1. Base Replacement, Base: step 1, image 1 of 1
      • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
      • Use a screwdriver to remove all four 11mm Phillips #0 screws.
      Ask FixBot
    2. Base Replacement: step 2, image 1 of 2 Base Replacement: step 2, image 2 of 2
      • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
      • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
      • The spudger is designed to make this step easier.
      Ask FixBot
Author
with
Han Shih
394 Reputation
4 Guides authored
IUPUI, Team 3-3, Harley Fall 2016 Member of IUPUI, Team 3-3, Harley Fall 2016
IUPUI-HARLEY-F16S3G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 220
