Shop the Holiday Gift Guide
Backyard Fence Post Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
34
Past 30 Days:
122
All Time:
722
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 4 hours
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Student In Progress
This guide is being worked on by hardworking students.
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a rotted or damaged backyard fence post.
Fence posts provide the main structural support for a fence. If even one post becomes rotted or damaged, the entire fence can become unstable or collapse, potentially resulting in costly repairs.
Replacing a fence post can be physically demanding and may involve hazardous tools and materials. Before beginning, put on safety glasses, work gloves, and closed-toe or steel-toed shoes. Keep your work area clear of clutter and potential hazards, and use caution when handling heavy tools.
    1. Backyard Fence Post Replacement, Backyard fence post: step 1, image 1 of 2 Backyard Fence Post Replacement, Backyard fence post: step 1, image 2 of 2
      • Measure the damaged fence post to determine the appropriate size for the replacement.
      • Take a photograph of the existing post and note where the fence boards and support beams are connected.
      • Clear the surrounding work area of clutter and potential hazards before beginning the repair.
      Ask FixBot
    2. Backyard Fence Post Replacement: step 2, image 1 of 1
      • Use a shovel to dig around the fence post until you expose the concrete base beneath the soil. Keep the excess dirt in a nearby pile, as you will need it to refill the hole later.
      • If necessary, carefully break off the upper portion of the damaged post with a pickaxe to create additional working space.
      Ask FixBot
    3. Backyard Fence Post Replacement: step 3, image 1 of 1
      • Continue excavating the soil surrounding the concrete base to create enough room to work with the pickaxe.
      • Use the pickaxe to break the concrete into smaller pieces, then remove the pieces from the hole.
      • Use caution when digging and breaking up concrete with a pickaxe. Flying concrete fragments and contact with heavy tools can cause injury. Wear safety glasses, work gloves, and appropriate footwear.
      Ask FixBot
    4. Backyard Fence Post Replacement: step 4, image 1 of 1
      • Carefully lift the damaged fence post out of the hole.
      • Leave the existing hole intact whenever possible to avoid unnecessary additional digging.
      Ask FixBot
    5. Backyard Fence Post Replacement: step 5, image 1 of 1
      • Insert the new fence post into the hole left by the damaged post.
      • If the post is loose, use some of the larger concrete pieces to temporarily support it while preparing for the next step.
      Ask FixBot
    6. Backyard Fence Post Replacement: step 6, image 1 of 1
      • Fill the hole with soil approximately halfway around the new post, leaving 6–10 inches of space below ground level for the concrete.
      Ask FixBot
    7. Backyard Fence Post Replacement: step 7, image 1 of 2 Backyard Fence Post Replacement: step 7, image 2 of 2
      • Use a power drill and wood screws to secure the existing fence support beams to the new post.
      • Install two to three screws per support beam to help keep the fence sturdy and properly supported.
      Ask FixBot
    8. Backyard Fence Post Replacement: step 8, image 1 of 1
      • Pour approximately 3–4 inches of concrete into the hole surrounding the new post.
      • Following the manufacturer's instructions, add room-temperature water to the concrete powder until it is fully saturated.
      • Allow the concrete to set for approximately 2–3 hours, or follow the setting time specified by the manufacturer.
      Ask FixBot
    9. Backyard Fence Post Replacement: step 9, image 1 of 1
      • Once the concrete has finished setting, cover it with the remaining soil.
      • Pat down the dirt to fill the surrounding area and create a level surface.
      Ask FixBot
    10. Backyard Fence Post Replacement: step 10, image 1 of 2 Backyard Fence Post Replacement: step 10, image 2 of 2
      • Align the replacement fence boards with the existing boards, making sure they are positioned evenly and flush with the ground.
      • Use a power drill and wood screws to secure the boards to the new fence post.
      • Install two screws near both the top and bottom of each board to help distribute the weight and provide a secure connection.
      • Once all the boards are attached, clean up the work area and check for any leftover screws or debris.
      Ask FixBot
Your replacement fence post should now be installed and secure. Check that the fence boards and support beams are properly attached and that the surrounding area is clean and free of debris.
Author
with
kaitlyn
189 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 34
Past 30 Days: 122
All Time: 722
