Backpack Mesh Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
75
Past 30 Days:
258
All Time:
2,895
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Mesh fabric is used in many items, and due to its thin composition, it can tear easily. We may feel inclined to throw away an entire item with mesh tears, as the damaged mesh can no longer function as it did before. In order to prevent unnecessary excess waste, use this guide to learn how to replace the damaged mesh on a backpack.
Tools
    1. Backpack Mesh Replacement, Backpack Mesh: step 1, image 1 of 3 Backpack Mesh Replacement, Backpack Mesh: step 1, image 2 of 3 Backpack Mesh Replacement, Backpack Mesh: step 1, image 3 of 3
      • Use scissors to cut out the entire piece of mesh.
      • Avoid cutting the elastic on the top.
      Ask FixBot
    2. Backpack Mesh Replacement: step 2, image 1 of 3 Backpack Mesh Replacement: step 2, image 2 of 3 Backpack Mesh Replacement: step 2, image 3 of 3
      • Use the mesh cut-out and a ruler to measure a new sheet of mesh.
      • Add 1 cm of seam allowance to each side.
      Ask FixBot
    3. Backpack Mesh Replacement: step 3, image 1 of 1
      • Thread your sewing needle, leaving a long thread to work with.
      Ask FixBot
    4. Backpack Mesh Replacement: step 4, image 1 of 3 Backpack Mesh Replacement: step 4, image 2 of 3 Backpack Mesh Replacement: step 4, image 3 of 3
      • Sew the sides and the bottom of the mesh with an overcast stitch to the backpack.
      Ask FixBot
    5. Backpack Mesh Replacement: step 5, image 1 of 3 Backpack Mesh Replacement: step 5, image 2 of 3 Backpack Mesh Replacement: step 5, image 3 of 3
      • Once done sewing all sides, tie off your thread 2-4 times and cut off the excess.
      Ask FixBot
    6. Backpack Mesh Replacement: step 6, image 1 of 2 Backpack Mesh Replacement: step 6, image 2 of 2
      • Insert an object to test the sturdiness of the new mesh. Pick up the backpack to see if the object can slip out and that the stitches are holding.
      • Check for any holes you might have missed while stitching
      • If there are stitches missing, return to step 4.
      Ask FixBot
Finish Line
Catelyn Bu
139 Reputation
1 Guide authored
UC Davis, Team 2-3, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 2-3, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G3
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 75
Past 30 Days: 258
All Time: 2,895
