Up to 20% off select tools
Back Panel
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
8
All Time:
142
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Back Panel
Tools
Introduction
Go to step 1 ↓
This guide will help you take apart your Garmin Dezl 760LMT to reach and replace needed parts.
    1. Back Panel, Back Panel: step 1, image 1 of 2 Back Panel, Back Panel: step 1, image 2 of 2
      • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
      Ask FixBot
    2. Back Panel: step 2, image 1 of 3 Back Panel: step 2, image 2 of 3 Back Panel: step 2, image 3 of 3
      • Using a metal spudger, pry the device apart.
      • To recombine them, line up the two halves of the device and press them together.
      Ask FixBot
    3. Back Panel: step 3, image 1 of 1
      • Turn the device over, laying it on its back with the screen facing upwards.
      • Lift the front panel away from the silver part of the back panel.
      • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
      Ask FixBot
Author
with
Ryan Williams
763 Reputation
6 Guides authored
USF Tampa, Team 4-2, Passmore Fall 2016 Member of USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 142
