Back of Bookshelf Replacement
  1. Back of Bookshelf Replacement, Back of Bookshelf: step 1, image 1 of 1
    • Gather all pieces of the bookshelf if it fell apart or the shelf itself is still together.
    • You will need two people to complete this project.
  2. Back of Bookshelf Replacement: step 2, image 1 of 3 Back of Bookshelf Replacement: step 2, image 2 of 3 Back of Bookshelf Replacement: step 2, image 3 of 3
    • You will need to put the bookshelf back together by holding the sides together.
    • Drill new holes to insert new screws to reinforce the shelf. Use a 1/8 inch drill bit.
    • Put screws into the freshly made holes with 1/8 by 1 inch wood screws to bring it together.
  3. Back of Bookshelf Replacement: step 3, image 1 of 3 Back of Bookshelf Replacement: step 3, image 2 of 3 Back of Bookshelf Replacement: step 3, image 3 of 3
    • Now that the base of the bookshelf is back together, we will need to measure out the size of board needed for the new backing.
    • Use the measuring tape and the square ruler to measure out the specific size you need. Use a pencil to draw the lines out so you can saw the piece out with precision.
    • Use the jig saw to cut the piece of plywood out following the lines you just drew.
  4. Back of Bookshelf Replacement: step 4, image 1 of 3 Back of Bookshelf Replacement: step 4, image 2 of 3 Back of Bookshelf Replacement: step 4, image 3 of 3
    • Line your new piece of plywood that you just cut, up with the back of the bookshelf.
    • Make sure that the corners are lined up so that as you hammer in the nails it stays lined up and even.
  5. Back of Bookshelf Replacement: step 5, image 1 of 2 Back of Bookshelf Replacement: step 5, image 2 of 2
    • Start from the top and work your way down each side when putting the nails in so the board doesn't bow.
    • Use 2d penny nails and hammer them in along all four sides.
    • Five nails on each of the four sides is all you will need.
  6. Back of Bookshelf Replacement: step 6, image 1 of 2 Back of Bookshelf Replacement: step 6, image 2 of 2
    • The shelf has its new plywood backing, so you can stand it up and you will feel the immediate difference in the sturdiness of your new shelf.
    • Place the shelf in the room of your choosing and place your books on it, knowing that it will not fall apart.
Finish Line
4 other people completed this guide.
Melissa Miller
241 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 112
All Time: 12,117
