Shop the Holiday Gift Guide
BUSY Bar Battery Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
96
All Time:
526
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your BUSY Bar or to remove it before disposing of the device.
Tools
    1. BUSY Bar Battery Replacement, Remove the back cover: step 1, image 1 of 3 BUSY Bar Battery Replacement, Remove the back cover: step 1, image 2 of 3 BUSY Bar Battery Replacement, Remove the back cover: step 1, image 3 of 3
      • The back cover is held in place by 8 clips.
      • Use a plastic card to release one of the clips near the center at the bottom of the back cover.
      • Gently release the remaining clips until the back cover comes off completely.
      Ask FixBot
    2. BUSY Bar Battery Replacement, Remove the screws: step 2, image 1 of 3 BUSY Bar Battery Replacement, Remove the screws: step 2, image 2 of 3 BUSY Bar Battery Replacement, Remove the screws: step 2, image 3 of 3
      • Use a PH1 Phillips screwdriver to remove 1 screw from the bottom and 4 screws from the back of the device.
      Ask FixBot
    3. BUSY Bar Battery Replacement, Pull out the front display unit: step 3, image 1 of 3 BUSY Bar Battery Replacement, Pull out the front display unit: step 3, image 2 of 3 BUSY Bar Battery Replacement, Pull out the front display unit: step 3, image 3 of 3
      • Do not pull the display unit too far out of the housing, as this may damage the display cable or connectors.
      • Do not disconnect the display cable. Always disconnect the battery first to prevent a short circuit when disconnecting flat cables.
      • Use a plastic card to release the 2 latches on top of the front display.
      • Gently pull the front display unit out toward the right.
      Ask FixBot
    4. BUSY Bar Battery Replacement, Remove the battery: step 4, image 1 of 3 BUSY Bar Battery Replacement, Remove the battery: step 4, image 2 of 3 BUSY Bar Battery Replacement, Remove the battery: step 4, image 3 of 3
      • Gently move the battery to the left so you can access the connector.
      • Use tweezers or your fingertip to press the connector latch.
      • Pull the battery connector to disconnect it from the PCB.
      Ask FixBot
Author
with
Flipper Devices
1,108 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 96
All Time: 526
