Up to 20% off select tools
BMS Replacement Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
39
Past 30 Days:
224
All Time:
685
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Follow this guide to replace the BMS in Zerotow 3024wH battery.
Only to be performed by competent people with battery experience.
    1. BMS Replacement Replacement, Set up: step 1, image 1 of 1
      • Start with a clean work bench
      • Remove all conductive a tools from your work bench
      • Wear safety glasses
      Ask FixBot
    2. BMS Replacement Replacement, Open the case: step 2, image 1 of 3 BMS Replacement Replacement, Open the case: step 2, image 2 of 3 BMS Replacement Replacement, Open the case: step 2, image 3 of 3
      • Use a stanley knife to cut though the sealant of the battery case
      • Use caution when doing this
      Ask FixBot
    3. BMS Replacement Replacement, Start opening the case: step 3, image 1 of 2 BMS Replacement Replacement, Start opening the case: step 3, image 2 of 2
      • Slowly lever the case apart.
      • Start at the bottom and work your way around to the handle
      Ask FixBot
    4. BMS Replacement Replacement, Completely open the case: step 4, image 1 of 3 BMS Replacement Replacement, Completely open the case: step 4, image 2 of 3 BMS Replacement Replacement, Completely open the case: step 4, image 3 of 3
      • Fully open the case
      • The glue is quite strong, use you hand inside to seperate the case from the heat shrink
      • Be careful to not damage the delicate switch wires
      Ask FixBot
    5. BMS Replacement Replacement, Removing the battery pack: step 5, image 1 of 3 BMS Replacement Replacement, Removing the battery pack: step 5, image 2 of 3 BMS Replacement Replacement, Removing the battery pack: step 5, image 3 of 3
      • Cut off the thick black shrink wrap
      • The main power cables and switch remain connected to the top cover.
      • Gently release and remove the switch cables from any adhesive so that they are not under stain when opening the case.
      • Rest the top cover on a box or similar to prevent staining the cables
      Ask FixBot
    6. BMS Replacement Replacement, Remove heat shrink: step 6, image 1 of 3 BMS Replacement Replacement, Remove heat shrink: step 6, image 2 of 3 BMS Replacement Replacement, Remove heat shrink: step 6, image 3 of 3
      • Remove the heat shrink from the battery pack.
      • go slowly at the cable end as to not break or stain any thinn switch cables
      Ask FixBot
    7. BMS Replacement Replacement: step 7, image 1 of 2 BMS Replacement Replacement: step 7, image 2 of 2
      • Remove the fiberglass sheeting from the pack
      Ask FixBot
    8. BMS Replacement Replacement, Remove the negative terminal: step 8, image 1 of 2 BMS Replacement Replacement, Remove the negative terminal: step 8, image 2 of 2
      • Remove the negative terminal
      • Cover the negative terminal with tape
      Ask FixBot
    9. BMS Replacement Replacement, Disconnect old BMS: step 9, image 1 of 3 BMS Replacement Replacement, Disconnect old BMS: step 9, image 2 of 3 BMS Replacement Replacement, Disconnect old BMS: step 9, image 3 of 3
      • Unplug the 4 connectors from the BMS. these will all be reused. do not cut.
      • Cut the large main negative cables from the BMS. There are 3-4 at each end of the BMS.
      Ask FixBot
    10. BMS Replacement Replacement, Cut switch light wire: step 10, image 1 of 2 BMS Replacement Replacement, Cut switch light wire: step 10, image 2 of 2
      • Cut the black switch light wire as close to the BMS as possible.
      • A connector is soldered to this in step 14
      Ask FixBot
    11. BMS Replacement Replacement, Remove old BMS: step 11, image 1 of 3 BMS Replacement Replacement, Remove old BMS: step 11, image 2 of 3 BMS Replacement Replacement, Remove old BMS: step 11, image 3 of 3
      • Fully remove old BMS
      • Desolder short wires from the main negative
      • Ensure all old solder locations are smooth
      Ask FixBot
    12. BMS Replacement Replacement, Prepare New BMS: step 12, image 1 of 3 BMS Replacement Replacement, Prepare New BMS: step 12, image 2 of 3 BMS Replacement Replacement, Prepare New BMS: step 12, image 3 of 3
      • Remove fibreglass from old BMS and install on New BMS
      • Locate new BMS as shown
      • Solder main Negatives as shown
      • The new BMS has all of the connections from one end only.
      Ask FixBot
    13. BMS Replacement Replacement: step 13, image 1 of 2 BMS Replacement Replacement: step 13, image 2 of 2
      • Only after soldering the main negative plug in the ballance, switch and temperature connections
      • Arrange as neatly as possible to avoid pinch points
      • Tape down to secure BMS in place
      Ask FixBot
    14. BMS Replacement Replacement, Switch light cable: step 14, image 1 of 1
      • The light for the switch is illuminated when the pack is turned.
      • Solder or crimp the eye terminal to the switch light wire that was cut in step 10
      Ask FixBot
    15. BMS Replacement Replacement, Cable Routing: step 15, image 1 of 3 BMS Replacement Replacement, Cable Routing: step 15, image 2 of 3 BMS Replacement Replacement, Cable Routing: step 15, image 3 of 3
      • The New BMS has different cable routing than the old one
      • Cut a slot in the fibreglass for the for the new BMS cables
      • Wrap the fiberglass sheets back around the BMS
      • Use duct of fiberglass tape close and seal the fiberglass sheets around the battery pack
      Ask FixBot
    16. BMS Replacement Replacement: step 16, image 1 of 2 BMS Replacement Replacement: step 16, image 2 of 2
      • Connect the main negative to the terminal on the battery case.
      • Correct order is Terminal - main negative lug - eyelet - bolt
      Ask FixBot
    17. BMS Replacement Replacement, Functionality check: step 17, image 1 of 2 BMS Replacement Replacement, Functionality check: step 17, image 2 of 2
      • Turn the switch on and off to check that the red light turns on and off.
      • Check the BMS app to ensure the all cells and connected to the ballance leads
      • Use ant BMS V2 app from the app store
      Ask FixBot
    18. BMS Replacement Replacement, Heat shrink the pack: step 18, image 1 of 3 BMS Replacement Replacement, Heat shrink the pack: step 18, image 2 of 3 BMS Replacement Replacement, Heat shrink the pack: step 18, image 3 of 3
      • Insert wisdom here.
      Ask FixBot
Author
with
Mark Duyvesteyn
1,581 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 224
All Time: 685
