BLU WIN HD LTE Battery Replacement
  1. BLU WIN HD LTE Battery Replacement, Back Case: step 1, image 1 of 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: step 2, image 1 of 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: step 3, image 1 of 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: step 4, image 1 of 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: step 5, image 1 of 2 BLU WIN HD LTE Battery Replacement, Battery: step 5, image 2 of 2
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
2 Comments
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Reply
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
raybrooks - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 641
