BLU Vivo 5 Mini Back Cover Replacement
  1. BLU Vivo 5 Mini Back Cover Replacement, Back Cover: step 1, image 1 of 3 BLU Vivo 5 Mini Back Cover Replacement, Back Cover: step 1, image 2 of 3 BLU Vivo 5 Mini Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Back Cover Replacement: step 2, image 1 of 3 BLU Vivo 5 Mini Back Cover Replacement: step 2, image 2 of 3 BLU Vivo 5 Mini Back Cover Replacement: step 2, image 3 of 3
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Back Cover Replacement: step 3, image 1 of 3 BLU Vivo 5 Mini Back Cover Replacement: step 3, image 2 of 3 BLU Vivo 5 Mini Back Cover Replacement: step 3, image 3 of 3
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Back Cover Replacement: step 4, image 1 of 3 BLU Vivo 5 Mini Back Cover Replacement: step 4, image 2 of 3 BLU Vivo 5 Mini Back Cover Replacement: step 4, image 3 of 3
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
Kymari
725 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 436
