Replacing the Battery on a BLU Vivo 5
  1. Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: step 1, image 1 of 2 Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: step 1, image 2 of 2
    • Remove the P2 screws.
    • Remove the SIM and SD cards, as well as the adapter.
  2. Replacing the Battery on a BLU Vivo 5, Remove the top cover.: step 2, image 1 of 3 Replacing the Battery on a BLU Vivo 5, Remove the top cover.: step 2, image 2 of 3 Replacing the Battery on a BLU Vivo 5, Remove the top cover.: step 2, image 3 of 3
    • Pull off the protective cover from the camera.
    • Remove the screws with a #00 Phillips screwdriver.
  3. Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: step 3, image 1 of 3 Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: step 3, image 2 of 3 Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: step 3, image 3 of 3
    • To remove the bottom cover, pull it upward.
  4. Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: step 4, image 1 of 3 Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: step 4, image 2 of 3 Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: step 4, image 3 of 3
    • Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
    • Remove the microphone/speaker board assembly by pulling downward.
  5. Replacing the Battery on a BLU Vivo 5, Removing the battery.: step 5, image 1 of 3 Replacing the Battery on a BLU Vivo 5, Removing the battery.: step 5, image 2 of 3 Replacing the Battery on a BLU Vivo 5, Removing the battery.: step 5, image 3 of 3
    • The battery has a small notch to facilitate removal, but the battery has been glued in place.
    • To remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
3 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Eneider Colina
2,362 Reputation
9 Guides authored
2 Comments
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
V'Ger_iTech - Reply
This guide is NOT for BLU Vivo 5. It's probably for the mini version. The BLU vivo 5 doesn't have screws at bottom...
Alaziz Hussain - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 26
All Time: 3,930
