BLU Tank II Motherboard Replacement
  1. BLU Tank II Motherboard Replacement, Back Panel: step 1, image 1 of 2 BLU Tank II Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
    Ask FixBot
  2. BLU Tank II Motherboard Replacement, Battery: step 2, image 1 of 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
    Ask FixBot
  3. BLU Tank II Motherboard Replacement, Front Panel: step 3, image 1 of 2 BLU Tank II Motherboard Replacement, Front Panel: step 3, image 2 of 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
    Ask FixBot
  4. BLU Tank II Motherboard Replacement: step 4, image 1 of 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
    Ask FixBot
  5. BLU Tank II Motherboard Replacement, Motherboard: step 5, image 1 of 2 BLU Tank II Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Locate the two 2.5mm screws (red circles in image) and remove them with the Philips 00 screwdriver used previously.
    Ask FixBot
  6. BLU Tank II Motherboard Replacement: step 6, image 1 of 3 BLU Tank II Motherboard Replacement: step 6, image 2 of 3 BLU Tank II Motherboard Replacement: step 6, image 3 of 3
    • Once screws are removed, separate the motherboard and outer lens by carefully pushing the motherboard out with your hand as displayed in the image.
    Ask FixBot
David Kelchner
632 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 576
