BLU Dash 3.5 Camera Replacement
    1. BLU Dash 3.5 Camera Replacement, Battery: step 1, image 1 of 3 BLU Dash 3.5 Camera Replacement, Battery: step 1, image 2 of 3 BLU Dash 3.5 Camera Replacement, Battery: step 1, image 3 of 3
      • Start by locating the slot on the lower right corner of the device.
      • Insert the opening tool into the slot.
      • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
      • A fingernail can work to open the back in place of an opening tool.
      Ask FixBot
    2. BLU Dash 3.5 Camera Replacement: step 2, image 1 of 2 BLU Dash 3.5 Camera Replacement: step 2, image 2 of 2
      • Locate the indentation at the bottom of the battery.
      • Insert your thumb and pull the battery out.
      Ask FixBot
    1. BLU Dash 3.5 Camera Replacement, Camera: step 3, image 1 of 3 BLU Dash 3.5 Camera Replacement, Camera: step 3, image 2 of 3 BLU Dash 3.5 Camera Replacement, Camera: step 3, image 3 of 3
      • Use the J000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
      • Use the opening tool to pry open the plastic back panel to expose the motherboard.
      Ask FixBot
    2. BLU Dash 3.5 Camera Replacement: step 4, image 1 of 2 BLU Dash 3.5 Camera Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Locate camera module on inside of the black plastic back panel
      • Note the orientation of the camera.
      • Use tweezers to carefully remove the camera.
      Ask FixBot
victoria dorony
22 Reputation
1 Guide authored
Ohio State, Team 1-2, Garvin Fall 2015 Member of Ohio State, Team 1-2, Garvin Fall 2015
OSU-GARVIN-F15S1G2
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 659
