BLACK and DECKER BDERO100 Hook and Loop System Replacement
  1. BLACK and DECKER BDERO100 Hook and Loop System Replacement, Hook and Loop System: step 1, image 1 of 1
    • Remove the sanding paper from the velcro.
  2. BLACK and DECKER BDERO100 Hook and Loop System Replacement: step 2, image 1 of 1
    • Select the JIS - J1 bit or the most appropriate bit to match the screws for your model.
  3. BLACK and DECKER BDERO100 Hook and Loop System Replacement: step 3, image 1 of 2 BLACK and DECKER BDERO100 Hook and Loop System Replacement: step 3, image 2 of 2
    • Use the Bit Driver to take off the four 12.5 mm Phillips screws at the base of the hook-and-loop system.
    • Be careful not to lose the lock washers (black rings).
  4. BLACK and DECKER BDERO100 Hook and Loop System Replacement: step 4, image 1 of 2 BLACK and DECKER BDERO100 Hook and Loop System Replacement: step 4, image 2 of 2
    • Once all screws and washers have been removed, hold the hook and loop system and separate it from the device.
Christian Moss
101 Reputation
1 Guide authored
USF Tampa, Team 1-5, Sullivan Spring 2016 Member of USF Tampa, Team 1-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G5
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,660
