This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
BERNINA Bernette not working
Fault: microswitch in the foot pedal is defective
Opening the footswitch:
Where the axle is hooked in, use a flathead screwdriver to pry the outer part outwards so that the internal nubs slide past ... replace the switch, check it beforehand with a continuity tester (UNPLUGGED!!)
The switch is normally open, but when the footswitch/lever is pressed, it switches to continuity...
Follow the steps in reverse order to reassemble your device.
