BEM Mojo 2 Charging Base Battery Replacement
  1. BEM Mojo 2 Charging Base Battery Replacement, Charging Base Battery: step 1, image 1 of 1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Battery Replacement: step 2, image 1 of 1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Battery Replacement: step 3, image 1 of 2 BEM Mojo 2 Charging Base Battery Replacement: step 3, image 2 of 2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Battery Replacement: step 4, image 1 of 1
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
Rachel Iacoboni
618 Reputation
5 Guides authored
Baylor, Team S1-G1, Johnson Spring 2018 Member of Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 407
