Azpen A720 Wifi Antenna
  1. Azpen A720 Wifi Antenna, Back Cover: step 1, image 1 of 2 Azpen A720 Wifi Antenna, Back Cover: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Wifi Antenna: step 2, image 1 of 3 Azpen A720 Wifi Antenna: step 2, image 2 of 3 Azpen A720 Wifi Antenna: step 2, image 3 of 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Wifi Antenna: step 3, image 1 of 1
    • Remove the rear casing.
  4. Azpen A720 Wifi Antenna, Wifi Antenna: step 4, image 1 of 1
    • Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
  5. Azpen A720 Wifi Antenna: step 5, image 1 of 2 Azpen A720 Wifi Antenna: step 5, image 2 of 2
    • Locate the soldering connection between the wifi antenna and the motherboard.
    • Using a soldering iron, melt the soldering connection between the cord and the motherboard and disconnect the cord.
    • The soldering iron gets very hot, be careful not to touch the tip to avoid burns. Click here to learn how to solder.
  6. Azpen A720 Wifi Antenna: step 6, image 1 of 2 Azpen A720 Wifi Antenna: step 6, image 2 of 2
    • Locate the black sticker connecting the wifi antenna to the battery.
    • Peel the black sticker off of the battery to disconnect the wifi antenna.
    • Remove and replace the defective wire.
Anna
353 Reputation
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,083
