Azpen A720 Touch Screen Replacement
  1. Azpen A720 Touch Screen Replacement, Back Cover: step 1, image 1 of 2 Azpen A720 Touch Screen Replacement, Back Cover: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Touch Screen Replacement: step 2, image 1 of 3 Azpen A720 Touch Screen Replacement: step 2, image 2 of 3 Azpen A720 Touch Screen Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Touch Screen Replacement: step 3, image 1 of 1
    • Remove the rear casing.
  4. Azpen A720 Touch Screen Replacement, Touch Screen: step 4, image 1 of 3 Azpen A720 Touch Screen Replacement, Touch Screen: step 4, image 2 of 3 Azpen A720 Touch Screen Replacement, Touch Screen: step 4, image 3 of 3
    • Use the plastic opening tool to gently lift the release lever for the ZIF cable.
    • The ZIF connector is delicate. Be careful not to damage the tab!
  5. Azpen A720 Touch Screen Replacement: step 5, image 1 of 2 Azpen A720 Touch Screen Replacement: step 5, image 2 of 2
    • Gently remove the ZIF cable from the connector.
  6. Azpen A720 Touch Screen Replacement: step 6, image 1 of 2 Azpen A720 Touch Screen Replacement: step 6, image 2 of 2
    • Disconnect the second ZIF connector using the same method detailed earlier.
  7. Azpen A720 Touch Screen Replacement: step 7, image 1 of 3 Azpen A720 Touch Screen Replacement: step 7, image 2 of 3 Azpen A720 Touch Screen Replacement: step 7, image 3 of 3
    • Locate the microphone. It is at the top of the device and next to the audio jack.
    • Using tweezers, gently remove the microphone.
    • Remember to reinsert the microphone when reassembling!
  8. Azpen A720 Touch Screen Replacement: step 8, image 1 of 3 Azpen A720 Touch Screen Replacement: step 8, image 2 of 3 Azpen A720 Touch Screen Replacement: step 8, image 3 of 3
    • Remove the three 4mm Phillips #00 securing the motherboard in place.
  9. Azpen A720 Touch Screen Replacement: step 9, image 1 of 3 Azpen A720 Touch Screen Replacement: step 9, image 2 of 3 Azpen A720 Touch Screen Replacement: step 9, image 3 of 3
    • Remove the motherboard from the casing, being careful not to damage the remaining wires.
    • It's okay if the buttons fall out of the case.
    • Flip the motherboard so it rests upside down and out of the way of the metal backing.
  10. Azpen A720 Touch Screen Replacement: step 10, image 1 of 2 Azpen A720 Touch Screen Replacement: step 10, image 2 of 2
    • Starting at the edge, use a plastic opening tool to carefully pry the front casing off of the metal backing.
    • Leave the plastic opening tool in place underneath the metal backing to prop it up.
    • Move the motherboard out of the way as needed.
  11. Azpen A720 Touch Screen Replacement: step 11, image 1 of 2 Azpen A720 Touch Screen Replacement: step 11, image 2 of 2
    • Using a second plastic opening tool, pry the adjacent side of the metal backing from the front casing/touch screen.
    • Pry close to the plastic tabs so you do not break them.
  12. Azpen A720 Touch Screen Replacement: step 12, image 1 of 1
    • Remove the first plastic opening tool and use it to pry along the second edge.
    • Slide the tool along the edge until it is close the next tab, and gently pry the metal up.
  13. Azpen A720 Touch Screen Replacement: step 13, image 1 of 3 Azpen A720 Touch Screen Replacement: step 13, image 2 of 3 Azpen A720 Touch Screen Replacement: step 13, image 3 of 3
    • Use a third plastic opening tool to pry at the corner of the tablet and pop off the metal backing.
  14. Azpen A720 Touch Screen Replacement: step 14, image 1 of 3 Azpen A720 Touch Screen Replacement: step 14, image 2 of 3 Azpen A720 Touch Screen Replacement: step 14, image 3 of 3
    • Lift the metal backing from the propped edge to remove it from the front casing.
    • Replace the broken front touch screen and casing with a new one.
Anna
353 Reputation
3 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 15
All Time: 2,771
