Azpen A720 Battery Replacement
  1. Azpen A720 Battery Replacement, Back Cover: step 1, image 1 of 2 Azpen A720 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Battery Replacement: step 2, image 1 of 3 Azpen A720 Battery Replacement: step 2, image 2 of 3 Azpen A720 Battery Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Battery Replacement: step 3, image 1 of 1
    • Remove the rear casing.
  4. Azpen A720 Battery Replacement, Battery: step 4, image 1 of 1
    • Locate the batteries' connection points.
  5. Azpen A720 Battery Replacement: step 5, image 1 of 1
    • A soldering iron can reach 600˚ F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
    • Use a soldering iron to melt the connections which attach the battery to the motherboard.
    • Disconnect the red and black wires from the motherboard.
  6. Azpen A720 Battery Replacement: step 6, image 1 of 2 Azpen A720 Battery Replacement: step 6, image 2 of 2
    • Peel the black sticker off the battery to disconnect the wifi antennae.
  7. Azpen A720 Battery Replacement: step 7, image 1 of 3 Azpen A720 Battery Replacement: step 7, image 2 of 3 Azpen A720 Battery Replacement: step 7, image 3 of 3
    • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
    • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
  8. Azpen A720 Battery Replacement: step 8, image 1 of 2 Azpen A720 Battery Replacement: step 8, image 2 of 2
    • Remove the old battery and replace it with the new battery.
Ben
280 Reputation
2 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 2,248
