Introduction
The battery in the A701 is located adjacent to the motherboard (the blue L-shaped piece) and has soldered wires. Before continuing, be sure you have all the necessary tools and safety equipment.
A guide to soldering can be found here.
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
Insert new battery by soldering red and black wires onto the motherboard.
"No parts required."
Hmmm.
Does the replacement battery not count?
A suggestion would be to mention a source for the plastic spudgers and replacement battery, or at least post the battery number. One could then search to determine if the part was even available, or the cost to determine if the replacement was cost-effective.
Thanks.
