Azpen A1045 Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
41
All Time:
318
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will show you how to properly locate and replace the front camera on your Azpen 1045 tablet. If your camera is blurry, cracked, or not working, follow these simple steps to safely remove and install a new one. No advanced tools or skills are needed just patience and care.
Tools
    1. Azpen A1045 Camera Replacement, Back Cover: step 1, image 1 of 2 Azpen A1045 Camera Replacement, Back Cover: step 1, image 2 of 2
      • Power off the tablet by holding the side button for five seconds.
      • Insert an opening tool into one of the sides and lift until the screen comes off.
      • This tablet is secured by clips on the sides; no adhesive is used.
      Ask FixBot
    1. Azpen A1045 Camera Replacement, Camera: step 2, image 1 of 1
      • Start by locating the camera, which is directly above the battery if you are holding the tablet front side up.
      Ask FixBot
    2. Azpen A1045 Camera Replacement: step 3, image 1 of 1
      • Using your iFixit opening tool, gently lift the black tab holding the orange ribbon cable.
      • This will unlock the cable so you can safely slide it out without damage.
      • Be careful not to use too much force, as the tab can break easily.
      Ask FixBot
    3. Azpen A1045 Camera Replacement: step 4, image 1 of 2 Azpen A1045 Camera Replacement: step 4, image 2 of 2
      • Remove the camera from the tablet.
      Ask FixBot
Aiden Lariviere
171 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 41
All Time: 318
