Azpen A1045 Battery Replacement
    1. Azpen A1045 Battery Replacement, Back Cover: step 1, image 1 of 2 Azpen A1045 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Power off the tablet by holding the side button for five seconds.
      • Insert an opening tool into one of the sides and lift until the screen comes off.
      • This tablet is secured by clips on the sides; no adhesive is used.
      Ask FixBot
    1. Azpen A1045 Battery Replacement, Battery: step 2, image 1 of 2 Azpen A1045 Battery Replacement, Battery: step 2, image 2 of 2
      • After heating your soldering iron, place it on the black wire and desolder it.
      • Repeat the same step for the red wire.
      • For more information on soldering, check out this guide.
      Ask FixBot
    2. Azpen A1045 Battery Replacement: step 3, image 1 of 2 Azpen A1045 Battery Replacement: step 3, image 2 of 2
      • Warning: Be careful not to puncture the battery, as doing so could cause it to explode.
      • Insert an iFixit opening tool beneath the battery and gently pry it up.
      • If you're having trouble removing the adhesive, use 91% or higher isopropyl alcohol. Apply it in small quantities with a syringe, if possible, to avoid damaging any electrical components.
      • After removing the battery, clean the area where the adhesive was, so it's ready for the new battery.
      Ask FixBot
3 other people completed this guide.
Alaa Kaliny
335 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 29
All Time: 311
