Audiovox T752 Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
69
All Time:
683
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This is an in-depth guide on how to replace the camera in your Audiovox T752. The guide includes step-by-step instructions and pictures to help you through the process.
Tools
    1. Audiovox T752 Camera Replacement, Back Panel: step 1, image 1 of 3 Audiovox T752 Camera Replacement, Back Panel: step 1, image 2 of 3 Audiovox T752 Camera Replacement, Back Panel: step 1, image 3 of 3
      • Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover.
      • NOTE: some force will need to be used to remove the cover. Avoid excessive force.
      Ask FixBot
    1. Audiovox T752 Camera Replacement, Camera: step 2, image 1 of 2 Audiovox T752 Camera Replacement, Camera: step 2, image 2 of 2
      • Remove the pink and aluminum protective cover. Be sure to also remove any tape holding it in place.
      Ask FixBot
    2. Audiovox T752 Camera Replacement: step 3, image 1 of 2 Audiovox T752 Camera Replacement: step 3, image 2 of 2
      • Remove the orange camera strip from the motherboard.
      Ask FixBot
      • Insert new camera strip and place the pink and aluminum protective cover back in the device.
      • NOTE: camera strip may be loose when reconnected. Use of electrical tape may be required.
      Ask FixBot
Logan
415 Reputation
3 Guides authored
Penn State, Team 2-42, Kaschak Winter 2015 Member of Penn State, Team 2-42, Kaschak Winter 2015
PSU-KASCHAK-W15S2G42
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 69
All Time: 683
