Audio-Technica AT-LP120-USB Outer Shell Replacement
    1. Audio-Technica AT-LP120-USB Outer Shell Replacement, Outer Shell: step 1, image 1 of 3 Audio-Technica AT-LP120-USB Outer Shell Replacement, Outer Shell: step 1, image 2 of 3 Audio-Technica AT-LP120-USB Outer Shell Replacement, Outer Shell: step 1, image 3 of 3
      • Remove the inner steel plate that spins on the turntable.
      • Carefully lift up the plate.
      • Place it near your device out of the way.
      Ask FixBot
    2. Audio-Technica AT-LP120-USB Outer Shell Replacement: step 2, image 1 of 1
      • Remove the power cord in the back of the device.
      Ask FixBot
    3. Audio-Technica AT-LP120-USB Outer Shell Replacement: step 3, image 1 of 1
      • Ensure that the Tone Arm clamp is in place.
      Ask FixBot
    4. Audio-Technica AT-LP120-USB Outer Shell Replacement: step 4, image 1 of 2 Audio-Technica AT-LP120-USB Outer Shell Replacement: step 4, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the eight 2 mm screws holding the back casing into place.
      • Carefully remove the back casing from the device to expose the interior.
      Ask FixBot
David
253 Reputation
2 Guides authored
Cuesta, Team 20-3, Krynen Fall 2024 Member of Cuesta, Team 20-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G3
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 57
All Time: 463
