Asus Zenfone 4 Max Camera Replacement
  1. Asus Zenfone 4 Max Camera Replacement, Camera: step 1, image 1 of 1
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: step 2, image 1 of 1
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: step 3, image 1 of 2 Asus Zenfone 4 Max Camera Replacement: step 3, image 2 of 2
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: step 4, image 1 of 3 Asus Zenfone 4 Max Camera Replacement: step 4, image 2 of 3 Asus Zenfone 4 Max Camera Replacement: step 4, image 3 of 3
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Maegan West
839 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,950
