Asus Zenbook UX303L Speaker Replacement
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: step 1, image 1 of 1
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: step 2, image 1 of 1
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: step 3, image 1 of 1
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: step 4, image 1 of 1
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: step 5, image 1 of 1
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: step 6, image 1 of 1
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: step 7, image 1 of 1
    • Carefully peel away the defective speakers from the battery.
Ryan Snow
200 Reputation
1 Guide authored
IUPUI, Team S1-G6, Harley Spring 2019 Member of IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Members
7 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 26
All Time: 1,750
