Remove all the nine screws from the bottom of the device using a T5 screwdriver.
Carefully remove the bottom cover.
Remove the three screws from the hinges using a PH-1 screwdriver.
Open the device at a 90 degree angle to free the hinges.
Remove the screw attaching the cooling fan to the motherboard by using a PH-1 screwdriver.
Disconnect the wire attaching the cooling fan to the motherboard.
Gently lift and pull out the cooling fan.
Remove the four screws attached to the black covered copper bar next to the cooling fan using a PH-1 screwdriver.
Gently lift and remove the copper bar.
Unhook the black, red, and white switch using the tweezers.
Detach the positive and negative red, white, yellow, and black switch.
Unhook the black and white coiled wire.
Lift and remove the battery pack.
Remove the three screws attaching the drive to the motherboard using a PH-1 screwdriver.
Gently lift and pull out the drive.
Remove the silver tape to free the fourth screw attaching the motherboard.
Remove the four screws attaching the motherboard using a PH-1 screwdriver.
Detach the four wires connected to the motherboard using tweezers.
Gently lift up and pull out the motherboard.
Remove the small piece of the motherboard on the lower left hand corner by removing the four screws using a PH-1 screwdriver.
Detach the black and red coiled wire from the motherboard using tweezers.
Gently lift and remove the small piece of the motherboard.
Place the plastic opening tool under the corners of the keyboard and use it to detach the keyboard all around.
Gently lift and remove the keyboard from its place.
