Asus ZenWatch 2 Speaker Replacement
  1. Asus ZenWatch 2 Speaker Replacement, Battery: step 1, image 1 of 3 Asus ZenWatch 2 Speaker Replacement, Battery: step 1, image 2 of 3 Asus ZenWatch 2 Speaker Replacement, Battery: step 1, image 3 of 3
    • Remove the four 3.5mm screws to detach the case using the T5 screwdriver.
  2. Asus ZenWatch 2 Speaker Replacement: step 2, image 1 of 2 Asus ZenWatch 2 Speaker Replacement: step 2, image 2 of 2
    • Slide the spudger under the battery and lift to remove.
    my zenwatch 2 is all together different it has a plug on top and a piece of metal hooked to the back of battery that looks like it is made on the watch
    glrichy - Reply
  3. Asus ZenWatch 2 Speaker Replacement, Speaker: step 3, image 1 of 3 Asus ZenWatch 2 Speaker Replacement, Speaker: step 3, image 2 of 3 Asus ZenWatch 2 Speaker Replacement, Speaker: step 3, image 3 of 3
    • Slide the metal spudger under the speaker and lift to remove it from the casing.
2 other people completed this guide.
Moriah
775 Reputation
3 Guides authored
USF Tampa, Team S1-G1, Leahy Spring 2017 Member of USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Members
10 Guides authored
2 Comments
Any idea where one might find a replacement for this speaker? Not having any luck in my search.
Danny Carbona - Reply
y el altavoz lo venden ?
Apoyo ICBF - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,156
