Introduction
The following guide is a step by step process for removing and replacing the battery on an Asus ZenWatch 2. Battery replacement may become necessary if there are issues with battery longevity and charging. Outside of a basic tool kit, no special requirements are needed to successfully replace the ZenWatch 2 Battery
15 other people completed this guide.
13 Comments
Where do you get the battery?
Sir,
I own Zenwatch 2 and it is just 14 months old. I left it uncharged for months. Now it is not at all charging. In Service Centre, they said Asus did not send any replacement spares even to test what was wrong.
I am from Mumbai, India. Where can i purchase replacement Battery so that i can try? Please help me sir.
Vijaykumar S
Mumbai
Only one place I know of to find them: http://www.asusparts.eu/Asus-0B200-01630...
Hello I have ZenWatch 2 Battery WI502Q-SL-BD need help looking Replacement Battery
i bought this battery as i belevied it to be compatible - but unfortunately the 2 contacts on the battery are not the same spacing as the original battery
anyone have any experience of swapping the circuit board of the contact between the 2 batteries? i feel this may be my only option of reusing my watch as this is the only manufacturer i have been able to locate :(
Now sold on Aliexpress https://www.aliexpress.com/item/For-Asus...
I’ve replaced the battery with an aftermarket one, but now I’ve attached the charging cable and it just buzzes every 2 seconds. No charging progress, no boot screen. I can’t find any mention of this anywhere, but my guess is it doesn’t detect the battery. Anyone see this before? I might have to open it up again and reseat the battery, and those tiny T5 screws are a pain — the worst part was getting them back in, they kept getting attracted by the magnetic charger!
My zenwatch is 3 years old, roughly.
When I bought the replacement battery, it too did not line up the contacts well either,
I held up the battery in the cover to the main housing of the watch and noticed how much the contacts were misaligned. I bent the posts slightly, GENTLY, and put the cover back on.
While I wouldn't recommend this, it does work.
I was ready to buy a different watch if I snapped a post, but got lucky.
I just hope this battery holds a charge better. I was getting about four hours of life from the original.
Update: the battery I used is the same as robert above. Here’s an amazon link for it:
https://www.amazon.com/dp/B07N7515XD/ref...
the battery has been giving me about 48 hours of use time.
sykmot -
Donde comprar batería para reloj Asus ZenWatch2 model:WI501Q
