Community-Contributed Guide
Introduction
Go to step 1 ↓The ASUS ZenScreen MB16ACV, is a portable monitor, but once you crack the display, it's worthless. Or is it? You can easily replace the display by following these instructions!
Start carefully prying on the edges of the bezel with a plastic pry tool.
BE CAREFUL OF THE BOTTOM SCREEN GLUE, IT MAY CRACK, BEND, OR BREAK YOUR BEZEL.
Now that the bezel is off, flip it on it's screen, and shake gently to remove the display.
Lift the latch on the cable that is colored red above the plug and fully push it back.
Pull gently on the cable, and it should pop right out!
