Introduction
The charging port is located on the bottom of the phone and is required for the phone to recharge the battery. It will be obvious that the charging port needs to be replaced, as the phone will more than likely either not charge at all, or take an unusually long amount of time.
This guide shows the use of metal tools in close vicinity to the battery. Choose to use plastic, ESD-safe tools for the procedure in order to greatly reduce the risk of a battery puncture.
On the bottom of the phone, lift up the silver press fit connector that is below the battery.
Gently lift off the gold headed coaxial cable that is connected to the motherboard and pull it away from the phone.
