Asus ZenFone 2 Laser ZE550KL Display Replacement
  1. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Rimozione sim e batteria: step 1, image 1 of 1
    • Rimuovere la cover posteriore
    • scollegare la batteria
    • rimuovere sim card e microSD
  2. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Rimuovere le viti: step 2, image 1 of 1
    • svitare le 15 viti
  3. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Cover posteriore interna: step 3, image 1 of 2 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Cover posteriore interna: step 3, image 2 of 2
    • rimuovere la protezione in plastica con dei plettri facendo attenzione a non rompere i gancini che la tengono in posizione
  4. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Flat cable display: step 4, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Flat cable display: step 4, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Flat cable display: step 4, image 3 of 3
    • scollegare i due flat sollevando il fermo bianco
    • scollegare la fotocamera
  5. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Altoparlante posteriore: step 5, image 1 of 2 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Altoparlante posteriore: step 5, image 2 of 2
    • con l'aiuto di uno spudger rimuovere l'altoparlante posteriore
  6. Asus ZenFone 2 Laser ZE550KL  Display Replacement, scheda madre: step 6, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, scheda madre: step 6, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, scheda madre: step 6, image 3 of 3
    • partendo dal basso sollevare la scheda madre
  7. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Frame Assembly: step 7, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Frame Assembly: step 7, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Frame Assembly: step 7, image 3 of 3
    • Logic board
  8. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Touchscreen driver: step 8, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Touchscreen driver: step 8, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Touchscreen driver: step 8, image 3 of 3
    • scollare il driver del touchscreen per poter rimuovere lo schermo
  9. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Rimozione dello schermo: step 9, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Rimozione dello schermo: step 9, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Rimozione dello schermo: step 9, image 3 of 3
    • con l'aiuto di un phon ad aria calda o un iOpener rimuovere lo schermo dal frame del telefono
  10. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Preparazione del nuovo schermo: step 10, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Preparazione del nuovo schermo: step 10, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Preparazione del nuovo schermo: step 10, image 3 of 3
    • Rimuovere i residui di colla sul perimetro del frame
    • incollare il flat del display in posizione
  11. Asus ZenFone 2 Laser ZE550KL  Display Replacement, incollaggio schermo: step 11, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, incollaggio schermo: step 11, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, incollaggio schermo: step 11, image 3 of 3
    • applicare il biadesivo al frame
  12. Asus ZenFone 2 Laser ZE550KL  Display Replacement, nuovo schermo: step 12, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, nuovo schermo: step 12, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, nuovo schermo: step 12, image 3 of 3
    • Prima di installare il nuovo schermo riposizionare la guarnizione antipolvere della fotocamera anteriore
    • Inserire il nuovo schermo in posizione facendo passare i flat nelle apposite scanalature
  13. Asus ZenFone 2 Laser ZE550KL  Display Replacement, Riassemblaggio: step 13, image 1 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Riassemblaggio: step 13, image 2 of 3 Asus ZenFone 2 Laser ZE550KL  Display Replacement, Riassemblaggio: step 13, image 3 of 3
    • Rimontare la scheda logica
Per rimontare il dispositivo, segui queste istruzioni in ordine inverso.
3 other people completed this guide.
gwsLabs
457 Reputation
2 Guides authored
One Comment
Just had my cracked LCD replaced. Everything was working fine before the replacement but after that, a third of a centimeter and all the subkeys (Back, Home, Recent keys) we rented working. The tech tried to checkout the fitting but it still didn't work. Had to install an assistive key app to be able to use the phone. He told me to go back on Thursday to replace the LCD with a different one cuz this last unit they had might be defective. Could it be a screen seating problem or an issue related to glue remnants or excess adhesive?
CJ Ogasawara - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 4,887
