Asus X555LA-SI305041 RAM Replacement
  1. Asus X555LA-SI305041 RAM Replacement, RAM: step 1, image 1 of 1
    • Flip your laptop upside down and set it on a solid surface.
    • The RAM is located under the square cover on the bottom of the laptop.
  2. Asus X555LA-SI305041 RAM Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to remove the screw cover.
    • Make sure to keep the screw cover in a safe place. It is very easy to misplace.
  3. Asus X555LA-SI305041 RAM Replacement: step 3, image 1 of 1
    • Using a #0 Phillips screwdriver, unscrew the single 25mm screw on the RAM cover.
  4. Asus X555LA-SI305041 RAM Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to open the RAM cover.
  5. Asus X555LA-SI305041 RAM Replacement: step 5, image 1 of 1
    • With your finger, push the two metal tabs (one on each side) outward until the RAM card pops up.
  6. Asus X555LA-SI305041 RAM Replacement: step 6, image 1 of 1
    • Gently remove the RAM card.
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 74
All Time: 20,711
