Asus X555LA-SI305041 Hard Drive Replacement
  1. Asus X555LA-SI305041 Hard Drive Replacement, Keyboard Assembly: step 1, image 1 of 1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041 Hard Drive Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041 Hard Drive Replacement: step 3, image 1 of 1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041 Hard Drive Replacement: step 4, image 1 of 1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041 Hard Drive Replacement: step 5, image 1 of 1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
  6. Asus X555LA-SI305041 Hard Drive Replacement, Hard Drive: step 6, image 1 of 3 Asus X555LA-SI305041 Hard Drive Replacement, Hard Drive: step 6, image 2 of 3 Asus X555LA-SI305041 Hard Drive Replacement, Hard Drive: step 6, image 3 of 3
    • Release the ribbon cables using the plastic opening tool to flip the gray tab on the white connector.
    • Gently slide ribbon cable out while gray tab is flipped up.
    • If glued, go ahead and peel ribbon from hard drive.
  7. Asus X555LA-SI305041 Hard Drive Replacement: step 7, image 1 of 2 Asus X555LA-SI305041 Hard Drive Replacement: step 7, image 2 of 2
    • Unscrew the one black 5mm screw from USB and headphone port using a #0 Phillips screw driver.
    • Remove USB and headphone port using the plastic opening tool.
  8. Asus X555LA-SI305041 Hard Drive Replacement: step 8, image 1 of 2 Asus X555LA-SI305041 Hard Drive Replacement: step 8, image 2 of 2
    • Unscrew the two black 5mm screws located in each corner of the hard drive using a #0 Phillips screw driver.
    • Lift hard drive out of device.
  9. Asus X555LA-SI305041 Hard Drive Replacement: step 9, image 1 of 3 Asus X555LA-SI305041 Hard Drive Replacement: step 9, image 2 of 3 Asus X555LA-SI305041 Hard Drive Replacement: step 9, image 3 of 3
    • Disconnect power connector with a plastic opening tool.
    • Unscrew one black 5mm screw from hard drive controller PCB using a #0 Phillips screwdriver.
    • Remove hard drive controller.
  10. Asus X555LA-SI305041 Hard Drive Replacement: step 10, image 1 of 3 Asus X555LA-SI305041 Hard Drive Replacement: step 10, image 2 of 3 Asus X555LA-SI305041 Hard Drive Replacement: step 10, image 3 of 3
    • Unscrew the four black 3mm screws from hard drive enclosure using a #0 Phillips screwdriver.
    • Remove case from hard drive.
    • Peel the three foam contact strips up slowly to ensure foam doesn't tear.
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 139
All Time: 52,844
