Asus X555LA-SI305041 Keyboard Assembly Replacement
  1. Asus X555LA-SI305041  Keyboard Assembly Replacement, Keyboard Assembly: step 1, image 1 of 1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 3, image 1 of 1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out and insert the cable.
  4. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 4, image 1 of 1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 5, image 1 of 1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 59
All Time: 8,933
