Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive
Views: 392K
View statistics:
Past 24 Hours:
10
Past 7 Days:
91
Past 30 Days:
560
All Time:
391,934
Comments: 172
116 comments on steps, 56 guide comments.
Go to guide comments
Completed: 361
361 people have marked this guide "completed." Will you be next?
Favorites: 221
221 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Lower Case: step 1, image 1 of 1
      • Remove the following ten screws:
      • Three 14.4 mm Phillips #00 screws
      • Three 3.5 mm Phillips #00 screws
      • Four 3.5 mm shouldered Phillips #00 screws
      • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 2, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 2, image 2 of 2
      • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
      • Remove the lower case.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Battery Connection: step 3, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Battery Connection: step 3, image 2 of 2
      • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
      • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 4, image 1 of 1
      • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Optical Drive: step 5, image 1 of 1
      • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 6, image 1 of 1
      • Carefully pull the camera cable out of its socket on the logic board.
      • Though not recommended by iFixit staff, some users opt to omit this step completely. For information on this, see the step comments.
      • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
      Ask FixBot
    3. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 7, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 7, image 2 of 2
      • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
      • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
      Ask FixBot
    4. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 8, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 8, image 2 of 2
      • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
      • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
      Ask FixBot
    5. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 9, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the following five screws:
      • Two 10.3 mm screws
      • Two 3.1 mm screws
      • One 5 mm screw
      Ask FixBot
    6. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 10, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 10, image 2 of 2
      • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
      • Move the AirPort/Bluetooth assembly and the subwoofer away from the top of the optical drive.
      Ask FixBot
    7. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 11, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 11, image 2 of 2
      • Pull the right speaker/subwoofer cable out from under the retaining finger near the side of the optical drive.
      • Pull the right speaker/subwoofer cable upward to disconnect it from the logic board.
      Ask FixBot
    8. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 12, image 1 of 1
      • Use the flat end of a spudger to pry the hard drive cable connector up from its socket on the logic board.
      • Bend the hard drive cable away from the optical drive.
      Ask FixBot
    9. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 13, image 1 of 1
      • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
      Ask FixBot
    10. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 14, image 1 of 1
      • Remove the three 2.7 mm Phillips screws securing the optical drive to the upper case.
      Ask FixBot
    11. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 15, image 1 of 1
      • Pull the optical drive upward from its edge closest to the display and remove it from the upper case.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Optical Drive: step 16, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Optical Drive: step 16, image 2 of 2
      • Pull the optical drive cable away from the optical drive.
      • Be sure to pull on the connector, not the cable itself.
      • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
      Ask FixBot
    1. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Dual Hard Drive: step 17, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive, Dual Hard Drive: step 17, image 2 of 2
      • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
      Ask FixBot
    2. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 18, image 1 of 3 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 18, image 2 of 3 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 18, image 3 of 3
      • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
      • Gently place the hard drive into the enclosure's hard drive slot.
      • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
      Ask FixBot
    3. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 19, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 19, image 2 of 2
      • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
      Ask FixBot
    4. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 20, image 1 of 2 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 20, image 2 of 2
      • Use two Phillips #1 screws to secure the drive to its enclosure.
      Ask FixBot
    5. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 21, image 1 of 1
      • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
      • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
      Ask FixBot
    6. Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 22, image 1 of 3 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 22, image 2 of 3 Installing MacBook Pro 13" Unibody Mid 2012 Dual Hard Drive: step 22, image 3 of 3
      • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
      • Align the cable's SATA connector with the drive's port and plug in securely.
      • Plug the USB connector into your laptop and your optical drive is ready for use.
      Ask FixBot
361 other people completed this guide.
Andrew Optimus Goldheart
515,980 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
56 Guide Comments
Has anyone else noticed their Macbook booting and responding slightly slower with this duel-hard drive setup? I first swapped out my main hard drive for a SSD and the computer felt amazingly quick. I then replaced the optical drive with another SSD for additional storage and backup and ever since then the computer has felt slightly more sluggish in general. I suppose the CPU now has to constantly communicate to the second SSD where it could mostly ignore the optical drive before. Has anyone else noticed this?
Landon McKee - Reply Share
Just fixed that issue:
Put the new SSD where the old HD used to be. Put the old HD where the optical drive used to be.
I found that the ports in the motherboard inside the mac have different speeds. The HD port is 6mb/s and the optical drive is 3mb/s.
chicle - Reply Share
Are you sure its MB/S that would be horribly slow.
Zarkex - Reply Share
I am seriously considering replacing my old HDD with a SSD instead of using a dual drive. Would you recommend still adding a dual drive with new SSD/ old HDD or just replacing the HDD with an SSD. I like having an optic drive, although not necessary. I am looking from the point of utility and practicality. Cheers!
nshourds - Reply Share
Zarkex is correct. The transfer speed for SATA 3 is not 6MB/s it is 6GB/s.
Gary Altonot - Reply Share
Past 24 Hours: 10
Past 7 Days: 91
Past 30 Days: 560
All Time: 391,934
