Introduction
Removing the keyboard plate cover will allow access to all internal components of the laptop.
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 17 mm screws in the middle of the back edge, and one 17 mm screw in the right edge
Two 9 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 5 mm screws in the front edge
Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
Invert the laptop in order to gain access to the ribbons.
Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
